Vintage Chevrolet Club Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
VISITORS: You are welcome to read our forums. If you want to participate FREE then you need to register. Join the VCCA and get access to the member-only features of the forum, including the ability to attach/upload photos. You'll also receive our monthly magazine "Generator & Distributor". Yearly membership as low as $25!
VCCA MEMBERS: Already a member? Great! Info to access the members-only area.
Topic Options
Rate This Topic
#329472 - 12/28/14 12:30 PM Spring ring Battery Cables
Billu38 Offline
Loc: Florida, USA
How many years did Chevrolet use Spring ring battery cables?? thx….Billu38
Top
Vintage Auto Garage - 12 Volt
#329663 - 12/30/14 02:52 AM Re: Spring ring Battery Cables [Re: Billu38]
tonyw Offline
Loc: Goulburn Australia
Too long, they were an absolute pain if the battery was disconnected often as they lost the clamp pressure.
_________________________
Top
#329667 - 12/30/14 04:48 AM Re: Spring ring Battery Cables [Re: Billu38]
Chipper Offline
Loc: The Great State of TEXAS
The earliest I have found is 1962 and latest 1969. Not sure that is 100% accurate.
Top
#329674 - 12/30/14 06:36 AM Re: Spring ring Battery Cables [Re: Chipper]
John 348/340HP Offline
1500
Loc: Glen Cove, NY/ Ocala FL
Bill,
As Chip already said they used them starting in 1962, and I know they used them up through 64, but I am not sure how much further after that. The spring ring cables were superceded to the clamp type terminal but still retained the same part numbers in Delco catalogs as the spring rings used, as they were a direct replacement. With one exception I had found. The NOS Delco service parts do not have the full run of wire to the voltage regulator, they have crimp butt splice to tap into the existing regulator connector. That way the same service replacement cable could be used on the 61-62, as the 63-64's that used a different regulator connection. The original factory installed cables were direct to the regulator with no splice. The Chevrolet part numbers will differ while Delco does not. On the full size cars like yours 4F-53 is the positive and 1964 they went from a 4F-22 to a 4F-30 on the negitive. I really did not look into why they went to the 30" negitive cable on the 64's. That was the last year of that chassis/platform, so it is strange that they would make a production change that late on a run.
The spring ring cables were used in other GM vehicles also. I know they were used as late as 1970 on some Buicks, I am not sure when they stopped on Chevrolets. I will do some digging tomorrow and see what I come up with, should be easy enough to find
John
if you never do nothing, you can never do nothing wrong! (think about it)
1950 2 door Styline Deluxe
1953 2 door 150 Sedan
1975 Cosworth Vega #0718
1977 Monza Mirage 305 4 Speed
1985 Caprice Wagon w/Chevy V-8
1987 Celebrity Wagon
2005 GMC Safari
2013 GMC Sierra 2500 HD Diesel
2015 Cadillac CTS
Top
#329688 - 12/30/14 02:44 PM Re: Spring ring Battery Cables [Re: John 348/340HP]
Chipper Offline
I have found references to '69 Nova and Camaro using spring clamp cables. Corvettes used them for several years. Think they started in '62 but not completely sure when they switched to side mounts. Side mounts appear to be what they went to after the spring clamps. The idea with side mounts is to get the connection away from the acid gas that comes out of the battery vents and accelerates corrosion of the post/cable connection.
Top
#329699 - 12/30/14 03:22 PM Re: Spring ring Battery Cables [Re: Chipper]
jiaccino Offline
Loc: Mostly sunny Tucson, Az
Camaro changed to side post batteries in early May 1969 unless the HD battery option was ordered & that was only a top post battery....Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
Top
#329703 - 12/30/14 03:55 PM Re: Spring ring Battery Cables [Re: Chipper]
1500
It did start in 1962
John
2005 GMC Safari
2015 Cadillac CTS
Top
#329752 - 12/30/14 11:26 PM Re: Spring ring Battery Cables [Re: John 348/340HP]
Chipper Offline
Maybe once we have a bunch of folks that have posted what they know or have found someone will summarize it into a table or ? Then it can be used as a reference in the case someone else wants to know if his cables are correct.
Top
#329754 - 12/30/14 11:41 PM Re: Spring ring Battery Cables [Re: Chipper]
Mike McCagh Offline
Loc: cumberland, md
spring ring battery cables were used in the corvettes starting in 63 and were used at least thru the end of 67 production. repos have been available for the past 20+ years(Lectric Limited corp) . it should be noted the repos are squared off(90 degree angle) where the top and sides of the terminal meet, whereas originals slope at the interface. mike
Top
#329874 - 01/01/15 03:50 AM Re: Spring ring Battery Cables [Re: Mike McCagh]
jimpala70 Offline
Loc: N.I.R.
1970 was last year used on fullsize Chevy's,unless HD battery ordered then it was side post. Jim
Top
#329880 - 01/01/15 11:17 AM Re: Spring ring Battery Cables [Re: Billu38]
Billu38 Offline
Loc: Florida, USA
Thanks to all…good info….Billu38
Top
#330004 - 01/02/15 02:17 PM Re: Spring ring Battery Cables [Re: Billu38]
p.k. Offline
pumpjockey
Loc: seligman ,AZ
Billu38: You might try corvette central they have the type of cables your looking for.
www.corvettecentral.com patriot
p.k.
1939 4 DOOR MASTER DELUXE SPORT SEDAN
1956 BEL AIR 2 DOOR HARDTOP
I'VE spent most of my money on Booze,Women,and mechanical things. The rest I just Wasted........
Top
#330031 - 01/02/15 06:29 PM Re: Spring ring Battery Cables [Re: Billu38]
Billu38 Offline
Loc: Florida, USA
The Corvettes are usually a different length than the full size Impala…but I'll look again..thx..Billu38
Top
#330033 - 01/02/15 06:33 PM Re: Spring ring Battery Cables [Re: Billu38]
1500
Bill, Show Cars in New Ulm Minnesota have the exact reproduction cables for your 64. They specialize in 58-64 full size, and their re-pop stuff is dead on. I have been buying stuff from them for over 20 years.
John
2005 GMC Safari
2015 Cadillac CTS
Top
#330079 - 01/03/15 01:09 AM Re: Spring ring Battery Cables [Re: Billu38]
Billu38 Offline
Loc: Florida, USA
Thanks John…just ordered their catalogue…never really heard of them but looks like they've got lots of parts…thx…Billu38
Top
Moderator:  AntiqueMechanic, d2d2
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
1 Chat Members (Peter_Gariepy), 0 Lookie Loo's and 25 Spiders or Bots online.
Key: Admin, Global Mod, Mod
Today's Birthdays
32confederate
Helpful Links
Forum Registration
New User Forum
Members Only Forum
Reset Your Password
Kill Your Cookies
VCCA Home
Join the VCCA
Member Photos
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
1936 Roadster - S. Africa
Chevy on the Levee
'37 Seat
Forum Stats
15086 Chat Users
79 Forums
50178 Topics
Max Online: 304 @ 06/18/16 10:00 AM
