Vintage Chevrolet Club Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
VISITORS: You are welcome to read our forums. If you want to participate FREE then you need to register. Join the VCCA and get access to the member-only features of the forum, including the ability to attach/upload photos. You'll also receive our monthly magazine "Generator & Distributor". Yearly membership as low as $25!
VCCA MEMBERS: Already a member? Great! Info to access the members-only area.
Topic Options
Rate This Topic
#324576 - 11/15/14 03:42 AM New Sealed 1929 Water Pump Impeller hits rear plate.
29guy Offline
Loc: san jose, ca
Can I space out the water pump to give it clearance at the impeller? It looks like I need about another 1/8 inch to make it run free.
Any Ideas?http://vccachat.org/images/icons/default/Frustration.gif
Top
#324579 - 11/15/14 04:00 AM Re: New Sealed 1929 Water Pump Impeller hits rear plate. [Re: 29guy]
Chev Nut Offline
Loc: West Allis,Wi.
Was the plate not driven back far enough? I believe it should be 1" back from the front surface of the block.
_________________________
Chevgene
Top
#324580 - 11/15/14 04:02 AM Re: New Sealed 1929 Water Pump Impeller hits rear plate. [Re: Chev Nut]
rjp Offline
Loc: wa
The rear plate will move . I used a stick of wood and a hammer and it moved easy. and the new pump works great.
Top
#324589 - 11/15/14 06:54 AM Re: New Sealed 1929 Water Pump Impeller hits rear plate. [Re: 29guy]
Junkyard Dog Offline
Loc: Eagle Point, Oregon
The baffle plate behind the water pump should be 1" back from the flange of the engine block. If it is you should have no problem installing the new water pump.
By the way, you should post in the 1929-32 forum instead of here in the "Chatter Information" forum which is for posts regarding announcements about the VCCA Chat Forum and it's capabilities.
Top
Moderator:  Bill Barker, Chevykid
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
1 Chat Members (Peter_Gariepy), 1 Guest and 29 Spiders or Bots online.
Key: Admin, Global Mod, Mod
Today's Birthdays
32confederate
Helpful Links
Forum Registration
New User Forum
Members Only Forum
Reset Your Password
Kill Your Cookies
VCCA Home
Join the VCCA
Member Photos
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
1936 Roadster - S. Africa
Chevy on the Levee
'37 Seat
Forum Stats
15086 Chat Users
79 Forums
50178 Topics
Max Online: 304 @ 06/18/16 10:00 AM
