Loosen the bolts that hold the rad shell and everything attached to it. Then using the rad support rod that runs from radshell to firewall, loosen those. Take the hood and lay it in place and adjust the opening front to rear of the hood sheetmetal gap using the rad support rods.
its time consuming to do it, but can save dollars from having to pay somebody.. Also if worried about chipping scratching the paint.
Take windshield washer rubber hose and split it with razor blade knife, place over the edges of the hood all 4 areas per side.
mike lynch............
