Posts: 3 |
Hi, I need help identifying a vintage Chevy 4cyl engine & body we have on our property. I have pictures but not sure how to post them. It's a 4 door. I have a few numbers off the motor- one is 4296158 on a plate below intake, then there is 348532 with the Chevy sign under it. Under the Chevy sign is what looks like D 5 8. Any help would be great!! Thanks, Sonja
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I believe the d 5 8 is April 5th of 1928. I'm sure some of the 4 cyl experts will shed more light on the numbers you posted.
Posts: 1,049 |
http://postimg.org/click on this set up account upload pic copy paste found at image codes (thumbnail for forums 1) and it should work
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Posts: 1,049 |
http://home.earthlink.net/~scrippsbooth/chev.html here is link for Chevy numbers after copy paste in browser you have to fix the earthlink.net for some reason it does not paste here is casting number info, 348532 is 1928 engine block http://hotrod.gregwapling.com/chevrolet/index2.html
Posts: 3 |
Thank you very much, I will try that 😊
Posts: 70 |
Photo of my 1928 Block I just pulled out, same number as yours. I am a novice at this but the stamped number above is the block production number (so no 2 are the same) If the head has the same number then you have a matched head and block telling you the head was never replaced...sort of rare i think.
Posts: 3,511 Likes: 47
Posts: 3,511 Likes: 47 |
Didier, I believe the bottom casting numbers in your picture say that the engine was cast on December (L) 31, 1927 (7). This means that your's is an early-1928 engine.
Posts: 1,049 |
