#321891 10/20/14 03:18 PM
I have a fuel gauge that reads empty with the key off and goes to full when turning the key on. And NO, the tank is not full. I disconnected the wire from the sending unit, The gauge still goes to full when turning the key on. This tells me that the wire is grounding out on the body some where. What do you all think?
Cleon
Cleon Eck #321914 10/20/14 09:25 PM
No when you ground the wire at the sending unit the gauge should go to empty so when the wire is disconnected the gauge should go past full. Try grounding the wire at the sending unit and if the gauge goes to empty then your wire and gauge are good, and your problem is the sending unit or the ground for it. All tests the key needs to be on.
dens41 #321949 10/21/14 01:10 PM
Thanks, I was thinking it was just the opposite. I put a jumper wire to the bumper and the gauge reads empty. Time to drop the tank.
Cleon
