Posts: 3,578 |
Do I need a reversing switch on my 48-216??I thought I either read or was told I did not-chef-
You either need the switch or you must modify the distributor/wiring. Or, replace the distributor.
If you have an early '48 it came with a reversing switch-a late '48 did not have it.The early '48 used what we called curved points-the stationary arm had a curve in it-the late has a straight arm.The early style curved points fit a 1941- early '48--the late also fit 1949 and up as well as 1933-40.
