#285335 08/01/13 10:04 PM
Jerry27 Offline OP
does anybody know where I can get a drawing with dimentions of a upper control arm mount for a 66 belair. I would like to fab mine rather than buy a flimsy repo. if anyone has a old one that I could use for a pattern, i'd be interested in buying one. thanks
Wilwood Engineering1955-1957
Jerry, I take it that you are referring to the rear suspension . If so you should be able to measure the other side, but access may be a bit difficult. I have a bare frame with rear suspension still on , let me know if that is what you need measured.
JACK
