#282388 06/30/13 10:24 AM
[Linked Image from i563.photobucket.com]
I was at a meet 40 miles from home,there was 1.5 miles of cars and I had a good time..Went to leave,pushed on the floor button and NOTHING?Checked the battery and all seemed to be good...Ran a screw driver from the battery switch to body and had spark...Wacked the starter a couple of times and still no go...After the masive exodus of about 800 cars I got a couple guys to push me for a compression start.Made it home,carefully,90 deg.in seattle and moving 20 MPH on the lake washinton bridge...Great view but the thermostat was climbing and if the Aero died on the bridge,I would cause a 5 mile long traffic jam ...Theres my adventure
A re-built starter and new switch was install about 6 months ago?? wazzup
chef-chevy #282407 06/30/13 03:19 PM
First thing I would check is the positive cable and battery terminal. That is far more common to have corrosion and therefore high resistance connection than dead starter. Next would be starter switch/solenoid. Starters typically just begin to lose power, run slower rather than just plain quit.
Chipper #282415 06/30/13 04:10 PM
Thanks Chipper,the battery is also very new and I checked the conection and they are clean..I still have the old starter and switch,the car did start fairly well before I changed it out, was (real old) FYI when I try to start the car there is "O"!! movement,noise etc.The current is not getting from the switch to the stater??I will try the old switch 1st
chef-chevy #282418 06/30/13 04:57 PM
Changed the starter switch with no luck...Its almost like the starter is frozen?When I press the starter button it pulls alot of juice but nothing happens..I had the door open and dome light on and it basicly turned off while pressing the starter
chef-chevy #282427 06/30/13 06:16 PM
Install the old starter and see if you still have the same problem.
chef-chevy #282429 06/30/13 06:18 PM
Bum starter...Not to worry...You would have had plenty of help to push... laugh 90 degrees @ 20 MPH, your bound to get hot...Lucky you weren't going uphill...
chef-chevy #282440 06/30/13 08:17 PM
Symptoms are leading more and more to bad starter. Guess the rebuilder didn't do a good job. As the puppy wrote put the old starter back on and see if that gets it starting again.
Chipper #282452 06/30/13 09:32 PM
The old starter goes back on ASAP
Has anyone out there had a simular problem" a stater that has plenty of juice but is frozen soild"??It does not turn at all
chef-chevy #282456 06/30/13 09:44 PM
When you remove the existing starter, hook it directly to a battery on the floor of the shop and see if it works then.
Thanks JYD thats the info I needed
chef-chevy #282546 07/01/13 01:40 PM
I pulled the rebuilt starter and sure enough,its frozen solid???
Need to clean up the old one a bit before installing,its a 39 and worked well for many years.too bad the newly re-build one "I beleive its a 48 with out a reversing switch"failed so badly
chef-chevy #282549 07/01/13 02:50 PM
Did one of the bushings lock on the shaft or a brush come loose and jam against the armature? Those are my first thoughts.
Chipper #282555 07/01/13 04:47 PM
No the brushes are all in place and in good shape..The rear gear to flywheel turns but nothing else move at all
chef-chevy #282565 07/01/13 05:43 PM
I had a starter that was "rebuilt" and acted the same way-would not turn at all. After inspection by a qualified shop it was found to be completely rebuilt, but one thrust washer was missing causing it to lock up.
m006840 #282597 07/01/13 09:46 PM
I must guess I have something of the same issue.Too bad I have had it for a year or so and never installed it until resently.No waranty on this one
chef-chevy #282603 07/01/13 09:57 PM
Your armature could be dragging on a pole shoe also.
When I get the old starter back on I will tear apart the re-built one,I'm sure the problem will be ovious?
P.S.for you filling station lovers...The re-built starter came fron Chevs of the 40's..This will be the second time I received a faulty part for them,I got a fuel pump with a leaky interior gasket,when I took it apart I found a deformed gasket...I need to start putting my parts on when I get them not years later!!! stupid
chef-chevy #282656 07/02/13 10:00 AM
.....or rebuild the parts yourself.
chef-chevy #282660 07/02/13 12:12 PM
Before you tear it apart I would suggest you bench test it first.
m006840 #282777 07/03/13 02:56 PM
Ok guys its not the starter...Its got to be electrical?With a different starter turned the key,press the floor button and still nothing?It does suck the juice though, turns the dome light off,should that happen
More thoughts please,help
The starter should turn also without the key on correct?should i disconect the wire from the ammeter,maybe there could be a short some where there...The cig lighter is connected to the same terminal and the lighter does heat
chef-chevy #282784 07/03/13 03:34 PM
I would still bench test the starter before installing. One post says the starter is frozen solid and your last post says its not the starter. If the starter spins on the bench then I would check the wiring and also turn the engine over by hand to be sure there is not a mechanical lock of some type.
chef-chevy #282787 07/03/13 03:45 PM
Well I'm charging a different battery to totally elimate the battery possiblity,we will see
chef-chevy #282793 07/03/13 04:28 PM
Steve6 the engine turns and runs fine ..I've got power to the starter switch but maybe not enough,we will see
chef-chevy #282799 07/03/13 06:15 PM
CC,
Did you check the switch on top of the starter? Sometimes we assume the worst.
.The current is not getting from the switch to the stater??I will try the old switch 1st......
