I put turn signals on my '48 Coupe and used a turn signal switch that has a bulb in the end of the stalk that blinks when you use the signal. Everything works, however, for a left turn, the stalk light blinks once and after that I just hear the clicking even though the lights are flashing normally. For a right turn, everything works normally. I replaced the flasher and the stalk bulb worked in both directions but at about 10 times the speed. Again, all the lights worked but at rapid fire. I know the lights all work; I know the stalk light works; I know the signal switch works, but what I don't know is why does the stalk bulb only work once for a left turn yet the turn signals are still working? Could it be both flashers I have tried are bad, they are both new, or does someone have any other ideas? Thanks. Beamer
