#277749 05/09/13 12:04 PM
My 36 water pump has about 3/8 inch end play. Seems like a lot. Is this normal ? The pulley self aligns with the belt and it works ok, I think. Thanks
Dick
Is this normal ?
No. There should be no end play.
I had a machine shop press in parts once. They forgot to put the spacer between the impeller and housing. That caused slop and the impeller to rub on the housing.
terrill #277814 05/09/13 10:48 PM
Either the thrust washer ground up or the pressed on pulley moved ahead. Ther is no housing or baffle plate on a 1936 for the impeller to rub on.
Chev Nut #277840 05/10/13 10:40 AM
I have two engines and the pumps are the same on both. The belt seems to keep the pump centered ok . No noise and no leaks. Thanks for the comments. My only concern was is the pump performing as it should ?
Dick
With end play the pulley, impeller and shaft will tend to move in and out while the car is running.
Hi Dick,
The pump will still perform okay, but with the shifting of the shaft you will need to keep a close watch that it doesn't pull in air, which is the enemy of the cooling system.
Agrin devil
