Posts: 1,869 |
Both I&I and FS are out. Any suggestions as to where I might look?
Posts: 977 Likes: 7
Posts: 977 Likes: 7 |
Bill Masters
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
Look closely at the ones on ebay. Many of the new ones are modern caps with a flat spot instead of dome. The seller has removed a warning sticker from this spot. Pat, I sent you a PM.
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
There is a used gas cap on ebay that looks correct.
Joined VCCA June 1, 1961
I should have mentioned the cap I'm talking about will need to be plated.
Posts: 1,869 |
Mike I ordered the one which says it's for a '34 Master. It was the third one in a row.
The ones I refer to are # 321098493176 does not have vent hole on the outside and # 261194737668 has a vent hole on the outside. They are not perfect. I have taken the skins off, straightened them and put the skin back on in the past and they come out very nice. I don't have the time or I would do it with thesw two.
