PHC30 Offline OP
Has any memebers fitted an Oil Breather to the Differential Housing on their 1930 - 31 Chevrolets ?
A mechanic suggested that it is a good idea as it allows for a release of pressure when the Differential Oil heats up under driving conditions.
Can you pls advise , Thank You,
Support The VCCA!
For a better response, you might want to post the above in the 1929-32 forum instead of here in the Vendors forum.
I have thought about it several times but haven't done it. There are breathers available that are about the same size as a greas fitting. It could be put in the cap near the top. If you try it, let us know how it works out.
Joined VCCA June 1, 1961
My 30 has a hole drilled in the top bolt that holds the cover on. I do not know if that is correct or not.
Online Happy
If you have the original non-sealed bearings and cork/leather/felt seals they will allow pressure from heating and cooling to be vented. If you have sealed axle bearings then you need to provide a vent.
PHC30 Offline OP
Chipper ,
I thought i did post it on the correct site 1929-1931, Sorry .
Anyhow I have fitted a Diff Oil Breather ( Toyota p/n : 90930 03031 ) at the top of the differential cover plate bolt hole . It seems to do the job .
At the time of posting i was unaware that it had Sealed Axle Bearings fitted, as i had purchased New Bearings and Modified Seals ( AF-82), Gaskets from the Filling Station , they did not suggest an Oil Breather in their literature, maybe they should update their site .
Thanks for the information and help as usual .
