Posts: 102 |
I have changed a lot of Oil pan gaskets in the 42-48 cars and have had no problem There is no need to remove any tie rod ends simply unbolt pan and it drops down enough to clear the crank.As for the rear main seal you can also fix that at the same time upper and lower if you have the right tools. I used a tool called a sneaky-pete it was only $12.00 US and it made it so easy to slide in the new upper rear main seal . Sneaky Pete tool After replacing rear main seal and sticking the gaskets to the block make sure to put a dab of silicone in the corners where the gaskets meet. I second that ... I have never had to remove the tie rods.Yes and while it is off do the rear main seal. The sneaky pete is the way to gol. Great tool and it just works. I will say this it is much easier to remove the oil pan gasket when it is on a lift. Doing it in the drive way on your back really sucks.
1947 Chevrolet Fleetline Aerosedan Country Club 1948 Chevrolet Fleetline Aerosedan 1948 Chevrolet 1/2 ton truck
Posts: 55 Likes: 2
Posts: 55 Likes: 2 |
Great, Im just now going to tackle the oil pan, great Idea with the 4 bolt studs
Posts: 55 Likes: 2
0 members (),
84
guests, and
20
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,062
Members18,308
