#268364 01/23/13 04:42 PM
chevy36 Offline OP
I have a 6 volt single terminal horn and I don't quite understand the wiring. I assume that the plus Battery connects to the horn terminal and the case is grounded via the connection to the boss on the manifold. Where does the single wire from the horn button connect? when this button is depressed it connects this wire to ground I think? any enlightenment would be appreciated
chevy36 #268374 01/23/13 06:41 PM
The wire from the horn button should go to a relay, and ground it. There should be a hot wire to the relay and also one from the relay to the horn.
dens41 #268435 01/24/13 10:39 AM
chevy36 Offline OP
Inside the horn there is a coil . One side goes to the single terminal and the other side to case ground. When power is applied to the horn terminal, the coil is energized and the contact opens. If I connect the lead from the horn button to the horn terminal, when I press the button the coil should be energized and the contacts should close. Is this how the horn works without a relay? what wrong with this picture. Can't find any wiring diagrams showing this system.
chevy36 #268486 01/24/13 06:58 PM
The horn will not work with out a horn relay. Power goes to relay and from relay to horn, horn button goes to relay as horn button is the ground.
Relay has three thermals power in power out and ground.
Al
a3alf #268555 01/25/13 10:50 AM
chevy36 Offline OP
Thanks Al,
I will get a relay and try that
a3alf #268612 01/25/13 10:00 PM
Al
I have a 37 truck and there is no horn relay. The small horn that bolts to the manifold does not need one. The hot wire goes to the horn and the wire from the button is ground.
chevy1937 #268613 01/25/13 10:15 PM
A single horn did not require a relay. The relay was used with dual horns due to the large amount of current draw.
Chev Nut #269010 01/29/13 08:31 PM
chevy36 Offline OP
Thanks guys,
I bought a relay and that should do it
