Posts: 145 |
I need help...can anyone tell me the dimension from the pressure plate mounting surface to the clutch face surface on a 1935 Master Flywheel?
I know I've seen it somewhere but can't find it...
Thanks,
Mike B
Mike Boteler 1935 Master Technical Advisor
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
According to the 1935 Master Tech Advisor , the measurement is 1.180" with a new clutch disc thickness of .122-.128" . These are quoted for the 1936 master in these posts, however all the parts for the clutch fit 1934 to 1937. Groups numbers , 0.863 , 0.861 , 0.886 . https://vccachat.org/ubbthreads.php/topics/42722/Re_flywheel_turning
JACK
Posts: 145 |
Thanks for the reply Jack!
I knew I had the info somewhere, just never thought to do a site search here first...lol
The clutch thickness of .122 - .128 is the thickness of each clutch disc, so the total thickness ot the assembled clutch disc will be about .125 (driven face) + .125 (drive face) + the thickness of the steel disc. The rivets need to be squashed to 7/32".
Mike B :)
