Posts: 3,136 |
I'd prefer someone else ( w/GPS perhaps )...Giving the rest a "thumbs-up" before diving in... :D: Thanks, Kevin Dear Russell, I was referring to you...lol ...If'n you purchase the adapter (speed-up/20%)...and check it w/your GPS to insure it is the correct one, and your satisfied with it...Then I'll buy one, too. Pretty sure we have the same ratio...
Posts: 1,743 Likes: 11
Posts: 1,743 Likes: 11 |
Oooooooooooooooh!!
Posts: 3,136 |
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Russell, Thanks for the information. Are you saying the GPS works on your stock 6-volt system just fine? Charlie
Hi Charlie, yes, so far. Please understand, I am not telling anyone to do this. I don't know about any other brand or model GPS. Just the one I have.
I tried to check the voltage at the plug end of the adapter but my hands are not steady enough to get inside that tiny space. I will try again this weekend.
Posts: 292 |
Most GPS unites run on 5.7 volts because the uSB plug on the cord that comes with the 12v adapter is a reducing voltage adapter, most accessories that use a uSB connector are 5.7 volts the same as a computer. I use a 6v to 12v converter in my 29 and 53 chevys to run my GPS and CB, also will charge my phone. Al
Posts: 11,162 |
anty one that has an old Car or truck probably has a need for a good battery booster -air compressor -trouble light set.
I have one that has a 12v outlet (cigarette lighter receptale, an air compressor, a floresent trouble light, jumper cables, and also a 300 watt 120 VAC invertor, I haul it in all my old cars on trips and have a couple of outlets for my GPS, Dixie air horns and CBs and walkie talkies, sit it in the rear floor boards and you are ready for about anything from a flat tire to a dead battery, day or night.
