#256286 09/27/12 10:55 PM
Nazario Offline OP
Hello, I was wounder if any knew if there was a fuse somewhere on the brake lights? My brakes are now not working. I replaced the switch on the master cyclinder and I checked the two lines going in to it and found no power. All my other lights work, but the brake light, no power going in or out.
My vehicle is a 1939 Chevy Master Deluxe
[Linked Image from i48.tinypic.com]
Do you have a shop manual or a wiring diagram for your 1939?
By the way, that is a great looking car!
Nazario Offline OP
Yes I do on both, I checked the diagram and it shows a fuse tomorrow morning I will drop the head light switch and see if there a fuse there.
I expect you will find the problem is a broken wire as the fuse protects all the lights. You wrote that the other lights worked.
One wire going to the switch should be hot.
Nazario Offline OP
Found the problem, The hot wire was broke. So I just ran a new wire to the switch.
Thank you
