Posts: 825 |
hi there, is there a rubber bung availiable that goes into the timing hole at the back of the clutch housing on my 34 chev std ,6 cylinder engine? see the picture:- Peter
never give 100% unless you are giving blood.
Posts: 1,294 |
No,not originally. McMaster-Carr would probably have something that would fit. Why cover it?
I would suggest leaving the hole open so air can be drawn in for clutch cooling. Some makes of cars had a hole with screen covering.
Posts: 825 |
just thought that on dirt roads, 80% of Australia is dirt roads, that it would suck in the dust and interfere with the operation of the clutch mechanism ! I will see if I can make a cover from metal fly-wire screen material.. Peter
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Believe it or not, back in 1934 a high percentage of roads in the U.S. were dirt, also. East of the Mississippi river, there is a very low percentage now, if you discount those trails around southeastern Ohio. Anyway, wouldn't screen door material just stop it up in short order? Unless you are splashing or throwing dirt at the hole, I don't think you have anything to worry about. It seems the starter might protect it from anything directly aimed at the hole from the ground. I have never taken off a flywheel cover and found anything in its bottom except a little oil residue and a few other minute particles, certainly not clogged up as might be expected. Owing to the spinning and closed clutch assembly, I don't see how dust could hurt anything. Centrifugal force would surely keep it sufficiently clean. Dust may possibly blow out the same way it got in. Maybe the clutch release (throw-out in TN and OH) bearing could be harmed by the dust, but I don't know. Have you experiencing any unusually shorter life span, than normally expected, for any of the components that are exposed by the holes in the bell housing and owing to dust getting in there? Unless you are, I would recommend leaving the hole(s) alone. As Gene pointed out there is the cooling effect. That may be more important than the screening effect you propose. Your call, of course. Best, Charlie
Posts: 825 |
hi there, thank you all for the input. the spinning effect of the flywheel may in some way help to expel any dust coming in, I like that idea. I will do nothing and see what happens. cheers Peter
Posts: 11,162 |
Posts: 825 |
Hi there Mr Mack, I thought that we only had pigs that fly in Australia, ours fly upside down BTW. Thinking about you idea of the exhaust pipe, I am now seriously considering fitting an exhaust from a BIG MACK truck..out the back and up about 6 feet, no dust up there, but on 2nd thoughts that would not be original, and I could not enter my car in the pebble beach concourse de elegance? hope we dont get this post deleted because we are off topic a bit? has happened recently to a friend on here, so sad... anyway ta ta 4 now Peter
Posts: 1,295 Likes: 2
Posts: 1,295 Likes: 2 |
This might be what your looking for ! CHEVROLET Timing Hole Rubber Plug (Rare) Timing Hole Plug. Rubber, rare For All Chevrolet Cars and Trucks 836802A ALL Click for more details www.chevsofthe40s.com $6.75 Each
p.k.
Posts: 11,162 |
That idea of using a stack off of a Mack truck has some merit, just be sure you put one of them rattleing weighted exhaust closer upper flapper valves to keep birds from nesting inside the stack, I guess that is what they are for, or maybe to keep rain out of the stack when you let off the gas and it sucks in a bunch of raindrops. I just put a peanut can over the one on our John Deere dozer, not a good idea, they blow off right after you start the engine. I actually had a problem with one of those aftermarket timing hole covers-leakseal thingies. I wanted to time a guys 235 and couldn't find the timing hole, thought it had been welded up.. but it had a rubber cover that had just been painted over with that god-awful battleship gray paint.
P.S. sorry about them pigs, there wasn't any pics of flying kangaroos available. Upside down? WOW!
Posts: 3,136 |
I found it a little interesting that there is a rubber plug for the timing hole...Perhaps this this is a "factory" item that is soon to be discarded...Much to the same fate as brake adjustment hole plugs...Just a thought...
Nooot so fast there, Kevin. I think the dust covers (metal or rubber) for the brake adjustment access serve a good purpose and, therefore, an item we would want to have in place. Charlie
Posts: 11,162 |
No, the timing hole cover is an aftermarket gadget, probably concocked to make someone some extra money from folks that will buy anything that will fit on their car whether it is needed or not. The dust covers for the brake adjusting hole are an original item and serve a purpose.
p.k.
Posts: 1,135 |
Nooot so fast there, Kevin. I think the dust covers (metal or rubber) for the brake adjustment access serve a good purpose and, therefore, an item we would want to have in place. Charlie I am a-gin the plugs in the timing holes...Being I am a soft hearted guy who is sympathetic to the possible plight of the poor homeless rodents should their nesting holes be plugged up. Were will the poor things go ??????>>>>ED
Posts: 3,136 |
Oh, I know the brake adjustment hole plugs serve an important purpose...Go tell that to "shade tree mechanics" and their brethren...Their the ones that usually toss'em to the wayside, just happy to be done with some miserable wretch's wreck...Thanks for the reminder though, I need to order some...
...As for those poor rodents...Your right, they need a nice comfy spot to digest all that new wire harness they been munching on...
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
...As for those poor rodents...Your right, they need a nice comfy spot to digest all that new wire harness they been munching on... Seat padding as well.
Tiny, That is a great image. Thanks for sharing the rats bedroom picture with us. What a trunk! Wow! That trunk is deep enough one could put down a pad, get a pee jug and tour the country. Betcha, the mice would get a kick of the trip. One could take them to see all their kin folk in Tennessee and Southeastern Ohio. They could spread a picnic lunch. Gnaw some cheese, so to speak. Cousins could... well, let's not go there. Tell me, is the 38 the mouse residence of choice. Do you reckon it's the ancient cotton upholstery that attracts such a plethora of them? They seem to be so prevalent there that one would think it was a most desirable preference for housing anywhere. Location, location, location, I guess. Having a 41, I haven't have the experience of furnishing living quarters to these critters. The 41 is too tight for them to invade and set up residency. Go figure. Tell me, is it true that no matter how hard one tires, a 41 can't be made into, or ever become, even through neglect, a rat-rod? Hmmm? Well, obviously, I do put up with one mouse. Just one. Best, Charlie
The old coupe spent a lot of years on it's belly in a barn before I drug her home. There were more than just mice living in her. The inside smelled BAD.
Posts: 1,135 |
Tiny, That is a great image. Thanks for sharing the rats bedroom picture with us. What a trunk! Wow! That trunk is deep enough one could put down a pad, get a pee jug and tour the country. Betcha, the mice would get a kick of the trip. One could take them to see all their kin folk in Tennessee and Southeastern Ohio. They could spread a picnic lunch. Gnaw some cheese, so to speak. Cousins could... well, let's not go there. Tell me, is the 38 the mouse residence of choice. Do you reckon it's the ancient cotton upholstery that attracts such a plethora of them? They seem to be so prevalent there that one would think it was a most desirable preference for housing anywhere. Location, location, location, I guess. Having a 41, I haven't have the experience of furnishing living quarters to these critters. The 41 is too tight for them to invade and set up residency. Go figure. Tell me, is it true that no matter how hard one tires, a 41 can't be made into, or ever become, even through neglect, a rat-rod? Hmmm? Well, obviously, I do put up with one mouse. Just one. Best, Charlie Charlie...I don't think you have to worry about mice invading your 41. Mice are smarter than you think. They like to take other mice home with them to "show off" their Pad,Dig's,Crash house...or whatever the hippest reference to "home sweet home" is at the time. I am sure no self respecting mouse would want to visit the cramped quarters of a "41" trunk...Especially one that is so far out of style and behind the times that the owner does not know yet that the United States now has 50 states opposed to 48 as the flag in the window shows.....ED
Posts: 825 |
Hi there P.K. that's just the part for the hole, thank you for finding it for me. I will order one today. that is an amazing site too.. cheers Peter
Happy to help....
p.k.
Posts: 825 |
just love that car, look at all the Patina,
providence and oodles of character.
The mice have very good taste (no pun intended) now I know where the term "rat-rod" came from. Should it be mouse-rod? love that car
TINY, have you done anything to the pictured coupe since the picture was taken. It appears to be pretty solid. It would make a nice looking car, if done right and you can keep Steve's hands off it. Solution for what to do with the mice thingee: Tow that car to Southeastern Ohio. Take a cat with you. Before the trip, withhold food from the cat for a few days. After you arrive and are stopped there to get a cool drink and pack of square nabs for the return trip, take a good look around to see if there are any police because what you are about to do is considered cruelty to animals, then, if the coast is clear, toss the cat in. The mice won't like it none too much but they will quickly see the wisdom of choosing between moving to new digs over being eaten alive. The choice will be real tough for them but, either way, you'll be rid of the mice. And, the new increase in the mice population won't even be noticed. EASTERN ED, The flag is period correct. There were 48 states when the 41 was made. You see, we add a star whenever a state is added so the original thirteen. But, I think you already knew that. The time was so short between Alaska and Hawaii being added, I can't remember for sure but I think we had a flag with 49 stars for a short period of time. Best, Charlie BTW: EE, Until relatively recent, the date chiseled into the the frieze on the Lincoln Memorial in Washington, DC that Ohio came joined the Union was incorrect. BTW2: Tiny, after the mice are scattered and there's no chance they will grab onto something and try to make the return trip with you, call the cat off. Buy it something nice for a job well done. Don't worry none about getting it back in the the tow car, after glancing around and seeing where it is, it will jump back in on its own. And hide. Will too!
TINY, have you done anything to the pictured coupe since the picture was taken. It appears to be pretty solid. It would make a nice looking car, if done right and you can keep Steve's hands off it. You might say I've done a "little" to it. I know all of you fog light, fender skirt and Fulton visor fans will just LOVE it.
