Posts: 165 |
Simple question. When using a disconnect switch on a 6 volt batt Should I put it on the pos or neg side? Thanks Stanman
earlychevguy
Posts: 29,847 |
Posts: 165 |
I realized that after I posted it. I'll be more careful. Why the negative side? Stan
earlychevguy
Posts: 3,136 |
..I suppose it's just "protocol"...You always disconnect the ground of a battery first...This Question is not 6 / 12 volt exclusive , no apology necessary...
Posts: 11,162 |
There is a realistic reason to disconnect the negative cable at the battery first. There is no potential between the negative cable and any metal on the car, so it won't spark and cause a high current flow if your metal wrench on the negative terminal fastener happens to connect with some metal part of the car, which can happen often if you are disconnecting the positive cable first and touch metal with your wrench while it is on the nut of the positive cable. then after the negative cable is removed the positive cable is also safe because the negative terminal isn't connected to the car metal either. Like wise you connect the positive cable first tnen the negative cable. Think about it and it makes good sense. I also would consider connecting the battery disconnect switch to the positive cable, because if it is connected to the negative cable all you have to do to "wire around" the disconnect switch is to connect a jumper cable to the negative terminal and then to any solid metal part of the engine, where you would have to attach a jumper cable to the positive terminal on the battery and connect the other end of the jumper cable to the (usually an insulated terminal) on the solenoid where the positive cable is connected, usually under the car at the starter. Doesn't that also make sense?
Posts: 3,136 |
How True...It's also a safety concern of mine...How many times have you watched someone ( like myself ) start loosening the POS. only to have the wrench ground-out and spark...I don't care for flame , fire , or sparks around my battery...It's not 4th 'o July and I don't care for fireworks...And Hey ! Don't forget to wear your safety glasses around battery work...As for the Disconnect , I don't know if I'll ever have time for that project...Heck , I'm happy if it's even RUNNING half the time...lol I like Steering Wheel Locks...
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
MrMack, You lost me at about the third line. Did too. Charlie
"You posted your six volt question in the Electrical - 12 Volt forum instead of the Electrical - 6 Volt forum." How dare he. Keep 'um straight there, JD. Charlie
Posts: 29,847 |
Posts: 11,162 |
Sorry about loseing you Charlie, I tried to word the information toward the adults here. Those that have completed "Normal" schooling or (8th grade).
Posts: 3,136 |
JD, Yeah, I shouldn't have done that. I regret it. I was just thinking that every little, relatively minor slip-up, as in the one Stanman made (in posting in the incorrect forum), didn't necessarily need pointing out. Especially when the same comments and applications were, or would be, common to either voltage. On hindsight I have concluded that you meant only to straightforwardly point out his error. Nothing more and a noteworthy comment. Nonetheless, I may have intended a bit of chiding but sarcasm was not. Yet I can see how it could be taken that way. I should have kept my thoughts to myself. Sorry. Respectively, Charlie
MrMack, I got lost owing to my limited education. It was't your fault. I need to go back to school so I can follow a more comprehensive thread on what I'm reading. I do need to get me one of those cut-offs, though. Nearly burned the coupe up a while back. Had an electrical fire under the dash (hot light wire shorted out) and couldn't get the darn battery cable off. Guess I'm waiting for it to happen again. Go figure. What is the best kind or make of those gadgets? My understanding is that some are better than others. And, not that it will matter much to me, but are points taken off for them? Charlie
Posts: 11,162 |
I have decided that the cut-off on the battery is a waste of money. I would need to know, when do I cut it off? and then when do I need to cut it back on?
I think that it has a handle on it that you move back and forth cut it off, cut it on. I am going to call it "lever B"..... like leave her Be, like it came from the dealer!
I figure if you are dumb enough to burn your car up, maybe you should not have a car.
Wow! I just thought how fast one of them Chevy Volts would burn up with all that plastic and all them batteries! "Quick , Bubba, call the fire Department, call 911!, Call Daddy!..Ma just plugged the power cord into the gas filler hole!"
2 members (Peter_Gariepy, 1 invisible),
40
guests, and
25
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,069
Members18,308
