glyn Offline OP
The post about buzzers brought to mind a problem I have with my aftermarket turn signal on the 52, when first installed the light in the handle of the switch would come on one time, that has since stopped and although I have cleaned ground spost of the steering column,cleaned all grounds and installed a ground from frame to ground cable cannot get the light to work as it is supposed to. I have checked the bulb it is good, I have replaced it with a new 6V that is a little to large but does not work any better. Any suggestions. I purchased the unit from the "Filling Station" several years ago. I am just now getting around to nit picking things.
I couldnt imagine, myself. Perhaps something faulty in the switch. A wire comming loose from a soldered joint. Anythings possible. I was very choosey when it came to a turn signal system. One thing is to stay away from ebay and the exessive cromey jobs becouse they have China stamped all over'em. I baught the signa-flair 900 from snyders which is U.S. made. Or they were at the time. No problems.
In my shop, quality is a standard, NOT and option.
are you using a 3 prong flasher one prong is power in one is power to signal lights the other goes too the warning light if it doesn't work change flasher good luck
