Posts: 165 |
Hi The book says the small screw head on dist housing represents #1 piston, then #2 clockwise from there Correct? There are two screws for the clips ,one for he condenser,the 3rd one is overthe delco plate. I assume that is the one. not sure , Thanks Stan
earlychevguy
Posts: 19,756 Likes: 62
Posts: 19,756 Likes: 62 |
I use the terminal closest to the tab on the cap. Or the depression in the top of the distributor. It is also closest to the middle screw (one without spring).
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
Firing order is 1,5, 3, 6, 2 & 4, clockwise on cap.
Posts: 78 |
I always remembered this way, 15 she's too young, 36 she's too old and 24 she's just right!
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
HA Ha, That wouldn't work for me. I'd have to go 153 she's too old, 62 she's just right 4 me!
Ed
Posts: 165 |
Chipper .. when you refer to the small screw in the dist body, is it the one directly above the "delco remy face plate? I'm still unclear where #1 is on my distributer cap. Thanks
earlychevguy
Posts: 29,847 |
The number one spark plug wire is located in about the 6:00 position on the distributor cap. It is also closest to the middle screw (one without spring). There are only three screws on the distributor body...two with spring clips for the cap and one without a spring clip. That is the screw located above the "Delco-Remy" name plate.
Posts: 165 |
Thanks.... This is one of those things that I need to "get right". Now I think I get it. Stan
earlychevguy
Topics59,070
Posts429,052
Members18,308
