The 1954 truck Engineering Manual says "An indicator for the directional signals is located at the bottom of the speedometer dial".
1954 was the first year for the non-clamp on signal switch. The 1950-1953 used the Guide clamp-on style. It was self canceling with the little rubber wheel.
The parking lights are used for the directionals in the front. They are converted to a double socket and 1154 bulbs are used.
Thanks for the info.
Did the double socket require a extra wire back to the signal switch.
Do you know where I can buy 1954,1955 1st series Chevrolet 3105 Panel Truck Engineering Manuals that are year specific?
I do have a 1954 shop manual & 1947-1954 Assembly manual, but they are reprints,and there is not much about the panel trucks.
I am trying to gather all the info I can on the 1954,1955 1st series Chevrolet 3105 Panel Trucks, So I can restore them to factory original condition.
Any info would be much appreciated.
Thank You,
jorb
