I have a CASCO 1940s 6 volt interior fan (rubber blades) that I wish to use in 2 old cars.
Car # 1 has a negative ground electrical system.
Car # 2 has a positive ground system.
A male plug is attached to the fan's electrical cord, which has 2 wires.
Please advise as to how to wire each of the female plugs to each of the cars.
(I plan to install 6 volt fuses in the cars.)
If I hook the fan up wrong briefly, on either car, will it damage the motor or will it just spin backwards?
Thank you,
Bill Harper
Thank you,
Bill Harper
