Posts: 476 |
On the pre-1940 Chevrolet headlamps, a dual contact bulb was used, typically with one element having 32 candle power for the bright lights, and 21 candle power for the dim lights.
I see there are dual contact headlamp bulbs having two 32 cp elements. What is the purpose of having two elements of the same candle power rating?
Mark Yeamans VCCA #35724
Posts: 7,033 Likes: 107
Posts: 7,033 Likes: 107 |
The output is the same but the aiming is different. High beam throws the light higher, further down the road.
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
I used 50-50 CP bulbs in our 31. They are hard to find. I found a full box of them in an antique store in a small town.
Joined VCCA June 1, 1961
What's the part number? I didn't know they were even made. I'll do some searching. I got a whole box of the 32/32s from my FLAPS so I have what will probably be a lifetime supply but I'd like to try a pair of 50/50s to see the difference.
Posts: 476 |
Tiny,
Thanks for the reply. I got the headlights on my 37 pickup re-wired and installed the 32/32 bulbs and road-tested it tonight, and I can see the difference.
Mark
Posts: 19,756 Likes: 62
Posts: 19,756 Likes: 62 |
I have a lamp bulb chart that lists a bulb number 1188 as a 50cp/32cp dual filament. Don't have a listing for the base type so can't guarantee they will fit but might be worth a try.
Posts: 287 |
1936 Low Cab Pickup
Wrong base Chip. The PN for the 32/32 is 2330 I believe.
I use 1000 for the 32/32 bulbs in my '31-2s but the later 2320, 2330 bulbs have the "prefocus" ring on the base. Original 21/21cp early 30s bulbs are 1110.
Posts: 133 |
Reviving an old thread.
I've ordered 1188s from somebody on EBay. They don't last long. And I mean maybe an hour on low beam. Voltage from the generator is fine so the problem is with the bulbs.
I know that FS has them, but I have been looking for another vendor. I just ordered a 10 pack from Candlepower, Inc. for $15.59 including shipping. I should have them in a day or two. I'll report back on how they work.
This post is guaranteed to be 100% content free! '31 Special Sedan
Search ebay for 1188 bulbs then click on ebay motors. I see a number of NOS bulbs for sale.
Topics59,071
Posts429,053
Members18,308
