Posts: 1,290 |
Is there an easy fix out their for squeaking brakes? My 31 sounds like a Mack truck when I come to a stop.(No pun intended Mr Mack) It does not go away if I try to put them on hard to warm them up either. There is always that little squeak when stopping. Or big squeaks when I first take off for a drive. I have almost 3000 miles on the car since compleated in 2008. One would think that by this time they should be worn in to some degree. Any body have any ideas???? Thanks
Posts: 558 |
Hi Sal,
Mine still squeak and squeal after about 10,000 miles, and I think they're worn in. The sound quiets down a bit after warming the shoes up, but it is still there and still very noticeable. Earplugs might help, or if you have a radio, turning up the volume. On the plus side, though, it does alert other drivers of your presence - especially the ones texting.
Dan
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I know exactly what you mean as I work for a Mack truck dealership and every time I come to a stop I'm reminded of work!!I have the lining with the brass strands and the only way I can reduce the noise is by braking with the clutch engaged, downshifting to slow down and then disengaging the clutch just before coming to a stop.With 10,000 miles the lining shows little wear and will probably last longer than me!!
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Sal Try putting a long spring around the outside of the drum but near the opening. It could well be vibrating brake drum and the extra metal upsets the resonance preventing the squeal. There were several vehicles down here that had this from the factory, when the spring fell off the brakes would squeal every application. Tony
Posts: 1,281 |
On my 32 Coupe, I have the woven lining with the brass In them. My squeaking brakes are on the rear when I apply them. I can come to a stop and pull on the emergency brake to stop and not once have I had the squeaking. The emergency brake lining Is the same as the other shoes. This tells me there Is something else besides the brass lining shoes that Is causing the squeaking. I have not taken the drums off to check further yet. Some of you guys might try the emergency brake to come to a stop and see If you get squeaking, If not I would check out something else causing the squeaking other then the lining. I have had dogs barking blocks away when I apply the brakes.
Posts: 1,290 |
Thanks for all the input. I just went through a situation were I had to stop in front of a whole bleecher section full of people to get my first in class award at a concours a few weeks back. When I got the go ahead to get up on the ramp I kept it in first all the way and then at the top I used my emergency brake with no squeaks at all. Talk about pressure. :) When I did the brakes I thought that there was copper strands of wire woven into the lining, but it could have been brass. But it is strange that the emergency brake does not squeak. Thanks again for all the input. Some day when I have nothing to do I will pull the drums and look at what I have. So as long as they stop me the folks around will just have to look for that Mack truck that is coming up behind them.
Posts: 221 |
I had the problem on my 32. I fought it for a long time. I called and spoke with an old gentleman at a brake shop who said he could fix it with no problem. He rearced the front shoes and it immediately stopped the noise. The noise was really embaressing!
Posts: 1,290 |
The noise is really embaressing. I could try calling the shop that did the shoes and ask them for their two cents, sure couldn't hurt.
