Will a '34-'35 (were not sure which yet) passenger engine fit in a '29 coach? Will the '29 bellhousing bolt up to the 34/35
block? Flywheel/PSI plate mating? What about the '29 in/ex manifolds fitting on the later block? My '29 coach's original engine is smoking some and I'm thinking about swapping engines so I can go through it for any potential problems. Any info appreciated! wink
Capt. Harley
