homer1 Offline OP
Got a Muncie M 20 trans. Before installing it I decided to take a look inside to make sure all looked good. Think I could of let well enough alone and just install it, But Billy Just Dont Do That. The shifter seals look leaky anyhow, so i removed the cover. Heard a clunk and the cover came, leaving the shifter forks out of place but in the case. First question after I replace the seals how do I put the cover back on and get the Long (i want to call them flat gears) on the cover in the right place? Did I mention that I dont know what gear it is in ? Next since im there I might as well see what ican screw up by replacing the front seal also.I see a retainer of some kind around the bolts.I figure I cant get in trouble with the rear seal. Besides that the trans looks great, no metal shvings, little dust on the magnet, thats it. Thanks guys
bill pearson
place both side cover shafts in their neutral positions, then place both 1-2 synchronizer and the 3-4 synchros in their neutral positions. place the forks in the side cover, then carefully position the forks into the synchros.ya might wanna get a shop manual to study the layout of a muncie. if you have questions of re-installing the side cover, you might wanna let the rest of the tranny alone, install in in your car and see what happens. if the front of the case is leaking gear oil, its usually not the gasket between the main case and the throw out bearing retainer, but rather the cluster shaft/case interface. that's a problem best handled by an experienced tranny rebuilder/machinist.good luck with your 4 speed.mike
homer1 Offline OP
thanks
bill pearson
