Posts: 128 |
Is there an easy way to tell if a brake fluid is regular dot 3 or is silicone? Mea culpa but I did not record what is in different cars.
Test for Dot 3 - put some on a painted surface (not on the car)....if it blisters the paint its Dot 3.
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Put a drop in a container of water. If it dissolves it is Dot 3. If Dot 5 it will not!
Posts: 128 |
Both excellent suggestions. Thanks
Posts: 49 |
Silicone is colored purple then over the years turns a yellow.
