Rating: 5
Page 2 of 2 1 2
aristech #270595 02/14/13 02:05 PM
Originally Posted by aristech
I have changed a lot of Oil pan gaskets in the 42-48 cars and have had no problem There is no need to remove any tie rod ends simply unbolt pan and it drops down enough to clear the crank.As for the rear main seal you can also fix that at the same time upper and lower if you have the right tools. I used a tool called a sneaky-pete it was only $12.00 US and it made it so easy to slide in the new upper rear main seal . Sneaky Pete tool
After replacing rear main seal and sticking the gaskets to the block make sure to put a dab of silicone in the corners where the gaskets meet.
I second that ... I have never had to remove the tie rods.Yes and while it is off do the rear main seal. The sneaky pete is the way to gol. Great tool and it just works. I will say this it is much easier to remove the oil pan gasket when it is on a lift. Doing it in the drive way on your back really sucks.
1947 Chevrolet Fleetline Aerosedan Country Club
1948 Chevrolet Fleetline Aerosedan
1948 Chevrolet 1/2 ton truck
Chev Nut #473759 08/31/22 04:16 PM
Great, Im just now going to tackle the oil pan, great Idea with the 4 bolt studs
aristech #473760 08/31/22 04:16 PM
Thank you I will do that
Page 2 of 2 1 2
