Posts: 49 |
Hello Folks:
I'm in the process of getting ready to install a windshield in my '37 Master Sport Sedan, "Ol' Satin".
My Manual Of Construction And Service (p 46) says to re-install the windshield garnish molding and to set it's screws but not to tighten them, as part of the process of working and straightening out the windshield rubber weatherstrip into the correct postion. Then the garnish screws are tightened.
Can one properly install the windshield without also installing the garnish molding, or is it needed to keep the windshield gasket aligned correctly while the glue dries?
I did a search on this subject, but I didn't see anything that specifically addressed this issue. Thanks!
Obob
Obob
Posts: 2,073 |
Hi Obob,
I just guessing at this, but when I had a 36 I removed the windshield to replace the rubber. I'm thinking that if you don't install the garnish molding the glass may fall inside when working around it on the outside.
I'm sure that if I didn't install the moldings on my 32 the glass will fall inside.
You may want to do as they say just to be on the side of caution.
RayG
Chat Group Chapter Member Current rides; 1968 Camaro rs/SS 350 4spd 2000 Blazer LT 2005 Malibu Maxx 2007 Acura TDX Last total restoration; 1932 Sport Coupe
Thinking back to when I replaced a windshield on my 1939 (same as a 1937) Tightening the garnish scrwes pushed the moulding, rubber cahnnel, etc. into the proper place.
