Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
Ray, I see that you placed the link over here, much better I feel it would get lost in the newer forum. Many of these cars ended up junked for this problem and I am sure many more will be junked or sold real cheap. This job was light as far as lifting but many, many, parts, it took all day but I could do the next in an hour or two. I made my own puller for the locating pins from a plumbing reducer fitting left over from my 62 vacume trunk opener and a stainless steel 8/32 screw and a nut. It was easy because it was in a truck with plenty of room, so I did not have to remove the column. I would recommend to all printing this out to keep in the shop, because one day it will be needed. John
John
This is a perfect example of the type information we need to preserve. If you have put together a similar topic, notify me and I will make it happen. You are able to access this column by a comment on a new subject, you may not start a topic.
0 members (),
91
guests, and
22
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
