Well I should of looked in my library before posting as I found a manual with a wiring diagram and it looks too simple,I found a diagram for a 53 olds and it goes F terminal on the generator goes to the F terminal on the regulator and the A terminal on the generator goes to the G terminal on the regulator and the B terminal on the regulator looks to be hooked to a constant 12 volt source that ends up at the solenoid. So it looks like there is no activation from the ignition switch or idiot light like on a alternator?. Jeff
