Posts: 4 |
I'm in Australia putting a 59 Elcamino on the road. With the 348 motor. Are engine rebuild kits available in the States, are any parts from the small block interchangeable. Thanks for any help. Clyde
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
SHOW CARS in New Ulm Minnesota sells complete kits or pretty much anything else you will need for your rebuild, they have an on line catalog at www.dr409.com The only part that will fit that I can think of from a small block is the fuel pump push rod. You had sent me a private message and I forgot to get back to you sorry, Good Luck John
John
The oil pump fits both engines....not much help.
Posts: 4 |
Thanks for the contacts, and information.
Posts: 4 |
Got a price on the rebuild kit, very surprised. Thanks very much. Any way to tell if my engine is a 348 or 409 before pulling it down. Is there documentation saying if it came out with tricarb, four barrel. Thanks for the help. Clyde
348 casting numbers 3732811 1958 early 3751872 1958 3755011 59-61 3771705 59-62 replacement and truck 3798962 62-65 replacement and truck (X on block) 3857655 63 65 truck (X on Block) 409 casting numbers 3795623 1961 3788068 1962 3830814 1963 (X on block) 3844422 1964 (X on Block) 3857656 1965 (X on Block)
The engine suffix on the pad will indicate what carb set-up
I will be back later with the codes dinner is ready John
John
