Posts: 61 |
i have a 63 chevy 2 ss. the temprature guage recently stoped working. this evening i put a jumper wire from the plug for the sensor, with the sensor disconected, to ground. the guage pegged full hot when i touched the key to the on position. that is a good thing cause i belive only ss chevy twos had guages, the rest were idiot lights. so now the next task is to check the sensor, guessing with a ohm meter. my question is what should it read cool, then hot? thanks guys
bill pearson
Hi Bill, Save your energy. If you ground the wire to the sensor and get a full deflection and no deflection when disconnected, the sensor is defective and should be replaced.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Another test connect everything up, warm the engine and connect a wire from sender case to a good ground or battery ground terminal if guage reads remove sender and clean threads. Tony
Posts: 61 |
that makes good sense, thanks. bill
bill pearson
